Hello new to the thread here. Was wondering if anyone had any tips on identifying engine models such as e7's 6's 9's and so forth by just appearance or some sort of distinguishing attributaries. Thanks for all the help in advance
Well i can help some here. First the 9 is a V8. The E6 is a 672 ci 6 cyl engine and has many different rating in it The E7 will be a 6 cyl engine and is easy to id from a E6. The E7 will not have the two panels that cover the cam lifters behind the air compressor and injection pump like the E6.That is the out side difference. glenn
https://www.bigmacktrucks.com/topic/4663-engine-identification/#findComment-23726
