If the dash gauges are not working it should not affect engine operations like the engine fan (cooking fan?). If the engine fan is not kicking on then you have other problems.
If you have an electronic viscous fan like a Borg-Warner (has a huge aluminum housing), you can unplug the fan, secure the connector, start the engine and within 30 seconds the fan should be fully engaged. If not then the fan is bad. Plus if it looks like oil is leaking around the hub then that is another sign the fan is going or is bad.
