When we are starting the engine, it starts with high steady RPM, but it wont accelerate when we're pumping the pedal.
Then after 10 - 15 mins. it will indicate a Engine Shut Down on the dash board then then engine will automatically shutoff.
And when we're trying to start the engine again, it will only takes 2-5 mins. then the same thing happens.
We try replace the EPS (Engine Position Sensor) and the PPS (Pedal Position Sensor) and check all wires but still wont work.
Hope you can give a advice.
Thanks.
low oil pressure, low coolant level, or high coolant temp will cause shutdown on them.
Check those first before going further
