Have a 1974 R model with a 350 cummins engine. the front mount rubbers are 2 piece the upper is close to 4 inches in diameter steps to 2.250 diameter and then down to 1.250 dia with a .875 hole in the sleeve.
 The lower is 3.750 diameter 1.125 thick id hole on the lower is 1.250 to allow it to mate with the upper mount. bolts together with .875 cap screw and large washers to crush it up. there are 2 of these mounts between the front engine mount and the cradle on the front cross member.
build record does not show these mounts for what ever reason, might have been built on Friday afternoon or day before Christmas vacation.
if anyone has a like truck with this style mount could you give me the part numbers of the rubbers or your chassis number so I can get some rubbers from
Barry...
Thank you.
R-700 front mount rubber drawing.pdf
https://www.bigmacktrucks.com/topic/46929-need-help-to-id-front-mount-rubbers/
