I have read elsewhere that 34k used aluminium components, was this strictly the case all th time?
Mine is all steel/iron so is this an indication it may be 38k?
By diffs I meant rear housing is cast and front housing is fabricated.
There's also difference in rear hubs. At least the ones with 8 stud shaft flanges exist (small flanges) and the six stud larger flanges. With different bearing inside.
I supposed to see big hubs with cast banjo's and small ones with stamped steel (fabricated). But recently found on at least two RD690's fabricated banjo housings with big 6 stud hubs.
And if the difference between 34K and 38K is springs only how to determine it for an air ride?
Vlad, you're right. I was told 34k diffs use a 5 spoke hub and 8 bolts on axle.
Same guy told me 38k use 6 spoke hub and 6 bolts for axles, but I've seen 6 spoke hubs with 8 bolts in axle.
I've found part numbers for 38k springs in this conversation here-
Also, the narrow part of the housing that goes to wheels is a bit different. 34k is round and 38k is more squared (so I was told).
Expand
A full 44 rear used to be the cast housings and six spoke hub, a 38 is the fabricated housing with the five spoke hub, and the only difference in a 34 and 38 were the number and thickness of the springs.   terry
Expand
Thank you for explaining that.
Sounds easy to figure out and keep in mind.
