At 1250 rpm it's showing 68 and it calls for 50-80 psi. Truck has gotten weak over the last couple of months. It's got new turbo, intercooler, injectors and Mack has checked the Egr valve and said it's work fine. I'm clueless and tired of throwing money at it.
https://www.bigmacktrucks.com/topic/47228-ac-fuel-pump/#findComment-348434
If the laptop says 32 psi thats good. All AC engines have a boost pressure sensor even if they dont have a guage in the dash. The laptop was reading off that sensor. Single or dual exhaust? We had several trucks here with single exhaust and the baffle would break inside the muffler and get side ways blocking off the exhaust flow.
https://www.bigmacktrucks.com/topic/47228-ac-fuel-pump/#findComment-348453
