ABS Light not working
In my 2004 Mack Granite CV713 the ABS light is not working.What i figure out is that the ABS ignition fuse(inside the fuse box under hood) is not getting the power and if you supply outside power to it,the ABS starts working.My question is that if it is safe to give that fuse outside power from another ignition point or it is better to open the fuse box and fix it from inside?Thanx
