When I bought my original (Russian) NR it had a Russian kind of 6-71 under the hood. The truck is basically similar to LF. And has almost similar hood. The earlier versions had closed L-model cab either.
The reason I'm posting that is the folks who fit the engine had to cut out the front chassis cross-member (the radiator support) to clear the crankshaft pulley. So I would expect seeing the same "customizing" in that LJ.
The tag tells LJT 1D which means single drive axle.
Looks like someone added a tag axle (or pusher?) to it.
https://www.bigmacktrucks.com/topic/47588-ljt/#findComment-351136
2 hours ago, BillyT said:
Heard you could make a Detroit leaker stop leaking with the proper seals on the pushrod tubes!
The fix is Viton Hi silicon/teflon seals and gaskets. That fixes the heat affects on the conventional seals. Tech comes from the Apollo program and  on a D.D. pre 80's H.D. or Corvair will seal them up where you'll get rust on the tin work.  :)
https://www.bigmacktrucks.com/topic/47588-ljt/#findComment-351314
