the pinned shoes with the c clips and the felts?  I changed my B over from that. found a U model with a cracked housing and took the spider backin plates, brake can mounts and S cams. reused my old slack adjusters. had to buy more shims for the slack and make one spacer for the s cam tube mount but yours might be a direct fit if you can find a modern set of spiders. this lets you use a modern shoe. mine also had 6 inch lining and I put on 7
