Quote
What can we do to keep our trucks from rust. Do you have any tips to share?
Move to the desert. Seriously, most older stuff was just not built to survive for 50 plus years, so total rust prevention was never an engineering goal. About the best you can do is keep after it and treat minor rust spots as soon as you can by cleaning and touching them up. Keeping the weep holes open and not allowing crap to build up like leaves and dirt that hold moisture is also important.
https://www.bigmacktrucks.com/topic/47778-to-avoid-rust/#findComment-352957
I always try to park on pavement or concrete. If your parking them on gravel or grass/dirt for periods of time it accelerates the rust. If there is something that i'm not planning on painting or otherwise making look nice again I use FluidFilm.
https://www.bigmacktrucks.com/topic/47778-to-avoid-rust/#findComment-352962
Keep the truck in the driest place possible with air circulation. If you don't have moisture rust can't get any worst or begin to start. Damp storage is a death wish for anything metal, it will even damage good paint over the years. Add salt mist or damp fertilizer and a truck is scrap in a short time. Storage out here in Arizona is great for anything metal, cars, trucks, planes, etc. as long as it is not directly in the sun all the time. Another story is paint, rubber and interiors will turn to dust exposed to sun and 120 degree heat for years.
https://www.bigmacktrucks.com/topic/47778-to-avoid-rust/#findComment-353349
