Some of the dimensions are the same but the B67 has the contour cab back panel as well as a large doghouse in the firewall to accommodate the motor.  Also, some of the motor options were the same between the two models but a B67 mounted the motor rotated toward the pass. side.
Is the engine positioned offset to the right or is it biased over the cranckshaft axle line?
Geez you cut the rear panel out and reverse it it'll look like it has a big blister seeing as it will go from concave to convex. :)
1 hour ago, carlotpilot said:
would sure help a long legged fellow though:thumb:
or a tail.    ;)
