My 1985 R688ST dump has broken the drivers side steering knuckle/spindle where the steering arm mount so I'm looking for either a front axle assembly Mack number faw537c (12,000 pound axle) or a knuckle part number 4qh312p2-preferably closer to Illinois if it's a entire axle.thanks
https://www.bigmacktrucks.com/topic/48025-front-axleknuckle/
Did you confirm 4QH312P2 is the correct part number based on your truck's model and serial number, and the 1QH front axle arrangement?
When you contacted Watt's Mack (provider of the BMT website) at 1-888-304-6225 for a 4QH312P2 knuckle, what did they say?
https://www.bigmacktrucks.com/topic/48025-front-axleknuckle/#findComment-354992
41 minutes ago, Damicoexcavating said:
Knuckle is still available buts it's pricey trying to find a cheaper alternative going into the off season
The larger issue here is, you're using a tractor with a 12,000lb front axle as a dump truck. The frame and axles are not designed for such loads. That's why your steering knuckle failed.
https://www.bigmacktrucks.com/topic/48025-front-axleknuckle/#findComment-355003
You have an R688ST. "T" stands for tractor. Sales Engineering would never allow dump body fitment onto a regular R-model. The frame and front axle aren't up to the task.
Even if you go to a heavier axle, then the tractor frame is the weak link.
If you could upgrade to a 14,300 lb FAW538 front axle and springs, sure that would help. But it would be challenging to find one nowadays.
An RD688S is a 6x4 dump chassis. "D" stands for dump. The RD has a deeper and thicker frame rail.
https://www.bigmacktrucks.com/topic/48025-front-axleknuckle/#findComment-355049
