Having problems with shifting, I have replace all trans harnesses  in cab to the truck harness, new engine harness, checked and made sure all  connections on trans are clean and tight NO CODES at all in V-MAC!!!when placing truck in gear sometimes will grab gear nice and smooth other times motor picks up rpm then grabs gear? Other times truck feels like brakes are on when you start moving?  I have ran power and ground direct to TCU and replaced all battery cables to starter and have cleaned and checked all firewall power and grounds, am I missing something? Has anyone else have this type of problem?
https://www.bigmacktrucks.com/topic/48081-2007-cxp613-ultrashift-problems/
