Looks like a lot of progress is done and still plenty of job in the future.
Good luck on the project!
If you will make some more pictures the other day please post a couple of views of the chassis very front crossmember. I'd like to see the difference of them between MH (I have) and Superliner. And also the way a RWII hood attaches to.
Can't wait to see the cab and hood painted.
Whonder which color.
Superdogs are damn attractive and many colors absolutely take them apart from other rigs.
Bring the pics up in the computer; click select all (top right); click save to and then pick where you want to save to (create a separate folder from the original) and it should give you an option of saving in original format or a smaller format.
Ok Vlad, here are some pics of front engine mount and of hood mount for ya, cross member and front engine mount in truck are out of a  RW753 for a CAT and the one one the ground came out of truck for an E-6. The hood mount would be the two holes at the bottom of the one pic and the two stand looking brackets at thr top of the other. Hope this helps.
