Whole lot of shimmying going on
Even though the king pins were replaced, was it done correctly?  Was the vertical clearance checked?
I had issues(shake) with my B and I found out the bearing caps needed tightening to get rid of the vertical slop(I replaced the pins about 10 yrs prior).  Once I tightened it up again, smooth as glass.
