I've got a 2001 cx613 Mack vision that doesn't switch between defrost, floor, dash and mix. I've replaced the controls but didn't fix the problem. I don't see any burnt or melted wiring. Can anyone point me in the right direction on how to fix this issue?
https://www.bigmacktrucks.com/topic/48308-2001-mack-cx613-heater-controls/
Not sure but in my R model it has air cylinders that move duct work to change heat flow. Could be cylinders not moving properly or duct work unhooked or stiff. I had heat problem in my R it was the cylinder not moving duct
Sent from my SM-G386W using Tapatalk
