Just started up my 98 CH in the shed for last two months, I think it's about 20 out?
Anyways, started right up and started "popping" back thru the air cleaner . Figured the air pump / wasn't building air and I shut off.
Assume I broke the air compressor when it started?
Any thoughts on this matter , and is it possible moisture froozen somewhere in the line??
https://www.bigmacktrucks.com/topic/48572-compressor-malfunction/
sounds more like a valve stuck open
Good idea, I guess I'll get a space heater under the hood in the morning and try thawing ! Didn't drain the air when I parked it last. Never had it freeze like this before ?
Once in the heated shop for service I'll be asking the forum what's involved in swapping the daytons for buds this week. Doing a brake job and a good time to swap over.
