I have a 06 granite it started out with the lighting bolt coming on every time I started pulling a hill for a second or to only when loaded code was 3-6 next day all the gauges stopped working shut truck off two times nothing sat for 20 mins turned key on worked fine next day gauges worked fine lighting bolt flashed couple time but at one point looked at mileage that was on but the hours were blank any suggestions thanks
Edited by bem1414
https://www.bigmacktrucks.com/topic/48599-granite-electrical-problems/
Check dash grounds on drivers side and passenger side dash. They are inside the dash. I had a similar complaint on one 9-2 was present. Followed a service bulletin for that code and found cab ground on passenger side dash was loose.
