It should take one gallon per mile they say! A massive consumption, how should it work technically, if you screw the carburator (updraft) away and use a tube with a flap and fill the gas directly in it will not take so much. The engine was built between 1927 to 1936 I think and they used it in AC, AP, BG trucks normally in firetrucks and commercial trucks? Anyone an idea if that is true can`t believe that. Had an old Army M62 5ton medium wrecker truck had around 600cui Continental 6cyl. and does not take 1quart per mile, but one gallon?
Thanks Matt
