On a 1979 RWS, there is a wire from the outboard junction block ter. #2 which runs to the reverse switch (either terminal) then a wire runs from the unused switch terminal back to the outboard junction block terminal #3.
Your success will be based on how many previous experts have done wiring work on the vehicle to make it "better".
https://www.bigmacktrucks.com/topic/49196-reverse-switch/#findComment-364992
