Rear tires for belt separation or odd wear and than look close for worn universals,  bad carrier bearing,a loose or worn drive shaft yoke or a biding or worn slide joint in the drive shaft. Those would be the first things I'd look at.    Paul
Edited by 41chevy
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-365214
45 minutes ago, Elitedownunder said:
 yes it is Newway air and which pinion angles ? the diff ones?
Yes the differentials. Like was said by J Hanncock ,the bags too high or too low with cause the u joints to bind along with other issues and you'll have a vibration. I didn't really think of that because it's there loaded or unloaded.
Edited by 41chevy
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-365239
Try dumping the air suspension while driving and see if that changes it. Do not drive very long with it flat.  Also, a bad U joint will cause that. I had that happen. Only way I found it was when I was putting the driveshaft back up I noticed the caps didn't turn freely. Didn't notice anything wrong when it was together and I shook the yoke.
Remember if it's got a hood it's no good!
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-365345
Thanks guys can only try these things, I did replace all of the UJ's and have just put on new ride height levers as suggested by J Hancock and adjusted as the others were bent...have a few more jobs on her and will let you know once I test drive her.
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-365448
been looking at this post since my truck has a wobble also. have checked everything and signs go to BAD tire. Just got them a short time ago.
Had a bad bearing, so replaced. didn't fix, ride height good, no loose tie rods,.....
When I replaced the bearings, noticed that several studs would have to be replaced next time.
Question-Can I use a small impact hammer to drive studs out while still on truck?  or pull hub?
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-367936
while it is normal for some to pound out studs in situ... it is considered bad practice by my profession as it does impart loadings on the bearings which can lead to premature failure... however, there are tools that use screw threads to re-re them and these are safe to use... if the studs are at the worn out point it is good practice to inspect the bearings and add a new seal.... in fact, a mini overhaul can then be done, s-cam bushings and slacks inspected.
see how I turned a 15 minute job into 2hrs...!!!  welcome to the repair industry..... LOL
BC Mack
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-367982
BC Mack
I kinda figgered that. Not a big deal though. Just thought I could save some BS.
https://www.bigmacktrucks.com/topic/49241-shake-that-thing/#findComment-367991
