if you couldnt keep uni joints in with a 453 how is a 6 53 gunna fix this problem ????
I hope your checking yoke angles as you go as this seems to be the main reason unis fail all the time
The little 53 series are something you either love or hate and Im most likely on the wrong side for you the 71 and 92 series are much more pleasant to drive for any distance
Good luck and keep us posted
Paul
yes we're definitely keeping 4wd. It was killing ujoints because all the old mounts were terrible and everything was moving around, also the largest joint i could get for the 4 spd was a 1310.....
v6 was just because i can.
After I did the engine over I noticed the turbo was leaking oil into the compressor housing, surging really bad, and wasn't making boost. I knew exactly what to do to fix it.
While I was upgrading the boost levels with a fresh coat of Alpine green I found an issue.
Muuuuuuuch better.
Edited by wayne64ss
