1 hour ago, beatngu said:
Copy that I'll grab a voltage reducer and take the pump apart
It will also kill the 6 volt coil. Simpler to get a 12 volt coil, points and condenser for the ignition rather than step the volts down.
Got the pump apart AC model D diaphragms are cracked. Going to hit eBay and google for a rebuild kit or replacement. I am thinking I could find a 12v points condenser and coil at napa if not tractor supply thanks for the heads up
Don't forget that the blower motor for the heater / defroster unless you can match up one, WILL need a resistor to cut the volts down to 6 or 8 volt.
Here is the pump I put on mine: https://www.amazon.com/gp/product/B000CIQ5DG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
It has two posts so you can use it on a positive ground system.
So looking into the 12v cool points and condenser I found there were systems with built in resistance and external resistors. I am thinking non resisted circuit, anybody know some part numbers to do this conversion? Being born into the age of fuel injection has its downfalls when working on equipment that is twice my age
Pre HEI GM had a resister wire from the ignition to the coil, Chrysler had a ceramic ballast  resister on the firewall , some had the ceramic resistor mounted on the coil bracket .and some had a resister built in to the coil . What they do is limit the voltage to the points them selves to prevent them from burning out. Generally the points and condenser will work with or without the resistor BUT they will fail sooner then not.
You could always run a Pertronix conversion and eliminate everything  but the 12 volt coil. You could get the Pertronix from NAPA, Auto Zone or and good parts store.   Paul
2 minutes ago, beatngu said:
Looks good.   Paul
I did the cheap and dirty just bought a resistor to wire before the ignition. Got the fuel pump in today so that will be part of the weekend projects. I plan to flip it to negative ground, just hook the battery up accordingly flip flop the coil wires?
It's been a long time but with a generator as I recall you need to re polarize it to charge correctly. Might have to swap the wires from side to side on the Amp gauge to read correctly also. . If you leave it as a positive ground gen and regulator it will fry the regulator and discharge the batteries when running.
1 - Polarizing procedure is same for positive or negative ground, 6 or 12 volt.
2 - The purpose of polarizing is to tell the generator whether to output positive or negative ground.
3-  Polarize generator. With engine not running and battery connected, momentarily jumper a wire between generator Armature post and battery terminal on regulator. Touch wire to nut on the armature post, NOT the threads as this will produce an arc and could damage threads
Edited by 41chevy
