What type of clutch?eaton pull clutch? 14 inch 15 inch?if you need help please post clearly what your working on?set the clutch linkage so you got a bit of clutch brake first and then adjust the internal ring so you got 1/2 to 9/16ths space between the throwbearing and the brake! If it's Eaton
Edited by fjh
https://www.bigmacktrucks.com/topic/49694-clutch-adjustment/#findComment-368733
                              Here's the link to Eatons clutch installation instructions. Scroll down to page 29
                               http://www.eaton.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/rr_clsm-0200.pdf
                                Truck Shop
One ping only
https://www.bigmacktrucks.com/topic/49694-clutch-adjustment/#findComment-368736
