- 0
99 Mack CH 613 intermittently overheating
Question
vvicess
99 CH with E7 is intermittently overheating, the truck can go for two weeks with no issues or it will overheat every day. if it overheats it happens around 6 hours after running. the truck has a new water pump, thermostat, new radiator ,new head gasket. can not find any coolant lines kinked or blocked the fan hub is operating properly. had the heads pulled off and checked out . i am not sure whats going on with this truck. any help would be appreciated.
https://www.bigmacktrucks.com/topic/49798-99-mack-ch-613-intermittently-overheating/Share on other sites
8 answers to this question
