i have a 1996 mack ch613 with a e7, I went to a fuel station to fuel up and when I went to turn it on it wouldn't start. it cranks but wont start and when I plug in the scan tool it wont communicate as if its not getting ignition power, put a brand new ecm and still nothing. it does start with starting fluid but dies right away, all fuses are good, cant seem to find the power relay to make sure that's all good, checked all the wiring from all sensors to the computer and all of them are good. if anyone can help that would be much appreciated.
https://www.bigmacktrucks.com/topic/49967-1996-mack-ch613-e7-cranks-but-no-start/
I forgot, being a 96 it's a VMAC-2 with 1 ECM.  I have attached the VMAC-2 troubleshooting service manual but sadly there is no "Crank no start" troubleshooting info in it like the VMAC1 and 3 manuals. It does have some ECM info in there though.
VMAC 2 manual.pdf
If you ever get th ECM to power up. There is a big cap nut on the front of the fuel pump that faces the fan . . It is  1 " or bigger. Remove it and stick your finder in the hole. Turn key on  and push throttle pedal to the floor, you should feel the rack push your finger .
