Ya, back in the 50's these were just "trucks" and door alignment was likely not worried about.  The fact it opened/closed was good enough.
I know I've played with my drivers door to try to make it work better.  The best I've done is using a bottle jack and 4x4 is press the door opening larger at the striker plate. Seems to help.  The passenger door works like a swiss watch, likely from never being used in 40 yrs?
https://www.bigmacktrucks.com/topic/49989-after-the-beach/#findComment-370838
I'm not going to worry too much about the gaps. They open and latch nicely,and are fairly even.
I've welded an 1/8 metal rod around the perimeter  of doors to build up the gaps a little tighter before.....add here, grind away there, this one will be ok though. It is what it is.
https://www.bigmacktrucks.com/topic/49989-after-the-beach/#findComment-370849
