Hi
I was wondering how far off the floor my clutch should be starting to grab. It
grabs high right now, almost to the top of the pedal.
The truck is a 1985 u600 mack. Is this normal, or to high ? As a note " it isn't slipping" just curious if there is something I should adress.
Thanks in advance for any replies
Jim !
https://www.bigmacktrucks.com/topic/5-clutch/
Hi
                                                          Jim !
Your clutch should grab about half way up from the floor...give or take. This should be true for most heavy trucks.
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-15
If you have a Spicer pull type clutch how much free play do you have in the pedal? A inch to 1&1/2 is normal, less and you may need to adjust the clutch.Spicer clutchs are adjusted internaly on the cover. Some late ones are self adjusting and the adjuster mat have quit.
Thanks for your help truxnut! I have about one inch of free play if that. I will have to adjust it.
Thanks
Jim !
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-44
This has always been a wonder of mine. I have looked thru the old owners manual about clutch adjustment but not wanted to touch it. Mine is kinda close to the top, but also does not slip. Guess it is okay for the mean time. Don't want to screw it up.. :P I don't know how many million miles are on it...but it works so I don't want to mess it up.
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-105
To adjust the clutch you adjust the pressure plate internally to get between 1\2 and 9\16 between the throwout bearing and clutch brake, then adjust the linkage to get 1\8 between the fingers and the bearing.after this is done measure the free play( whatever it is,is right at this time) and when you loose 1\2 of whatever you have it is time to adjust again. This is from the spicer book.
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-110
On normal car/trucks you adjust the throw out arm for clearance. Here you adjust the plate for clearance from the throw out. Hmmm, okay. That is the reason I have not dug into it. I have read people that have got it screwed up somehow and don't have pedal anymore :pat: . Don't want to get into that.
Some day when I have nothing better to do....maybe I'll swing under it and start poking around.
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-111
Back in the GOD (Good Old Days), a 1/2 in socket extention made a great gage for that 1/2 in adjustment.
Packer
Keep a clutchin'
https://www.bigmacktrucks.com/topic/5-clutch/#findComment-242
