thanks for the info.
i am thinking i will splice a long wire from   the sending unit (ground wire)  and route it inside the cab and when the gauge decides to act up i could touch that wire to a ground source inside the cab
just to see if the gauge stops acting up.   think i will leave the sending unit  hooked up as original but run a jumper from the ground  wire to inside the cab.
thanks again
