Thank y'all in advance, just looking for some pointers here. I have a 95 ch600 that dies when cold started. Apx 30 seconds after cold start it electronic malfunction light comes on then engine shutdown light after. If I rev it the engine shutdown light will go off but come back on a couple minutes later. It will do this 4 or 5 times until the motor is warm then run fine all day. All fluid levels good.
https://www.bigmacktrucks.com/topic/50040-95-ch600-electronic-malfunction/
If it has cruise control, with the key on engine off, turn on the cruise then press and hold the set button. Count the flashes. This is find out what code you have. There will be 2 series of flashes, i.e 6-2. Electronic malfunction lamp flashed 6 times, pause then flashes twice. Can call Mack dealer and they can decode for you
