- 0
Vmack 3 will not hold memory
Question
reapermp
I have a 2004 MR that has a 5-1 blink code fmi 13 out of calibration. I have calibrated it manually and with 2 different laptops.The calibration is fine until you turn off the key, then you have to recalibrate because the rpms are limited to 1400. I have tried going into the truck using may vmack software, no matter what I do weather it is set the clock or turn off the idle shut down I press save and exit, cycle the key , go back in and everything has went back to what it was before I changed it. Engine and vehicle computers replaced with new still same problem.
DON'T FEAR THE REAPERMP
https://www.bigmacktrucks.com/topic/50059-vmack-3-will-not-hold-memory/Share on other sites
4 answers to this question
