that is the electrical malfunction light.  macks version of a check engine light.
to retreive the fault codes:
with engine running, Turn speed control switch Off, then press and hold SET/DECEL or RESUME/ACCEL switch until EML goes out.
 After approximately one second, the V-MAC module will begin blinking out its two-digit blink codes. The two digits of each code will be separated by a one second idle time (EML out)
Each blink code digit may consist of up to nine on–off flashes. The on and off time for each flash will be 1/4 of a second.
Count the EML on flashes to determine two digit blink code.
https://www.bigmacktrucks.com/topic/50066-lightning-bolt/#findComment-371442
