Hi again everyone ,I am  looking to purchase a 1993 cl 713 Mack .it has a 425 cat,13 speed and 4.42 Mack rears on camelback springs. is this a good set up to pull Michigan gravel trains.(grossing 154000). My concern is that it won't go fast on freeway.are the 4.42s to steep? Truck is original to my knowledge.
https://www.bigmacktrucks.com/topic/50080-rear-end-ratio/
How fast do you want to go with a Michigan train? With an overdrive 13 you should be good for 70 mph. And the Mack 4.42s are bulletproof.
Sent from my XT1254 using Tapatalk
https://www.bigmacktrucks.com/topic/50080-rear-end-ratio/#findComment-371574
