I know someone here has seen this set up before,ive got a Kysor roof A/C and the Kysor evap unit in the hump,when i got the truck,only the roof was hooked up, im wanting to hook up both and am seeking information as to tie both together,the only condenser is in the roof unit,no room for a condenser on the radiator as its fitted with the shutters, common sense says to tie the low side from the roof unit to the high side of the in cab unit,then finish the circuit back to the low side of compressor,any help would be appreciated,
https://www.bigmacktrucks.com/topic/50232-73-mack-western-f787/
