Somebody correct me if I'm wrong but I don't think you can disconnect the steering shaft from the box without disassembling the box. In order to remove the steering column the box along with the shaft have to be disconnected  from the frame and removed from the bottom.
The column stays on the box and as for as i know it cant be removed but pull steer wheel and then in the floor ifi remember there is a panel you remove to give it room it go down and slide forward on the ground and under the axle.
