Need some help a friend gave me a 1985 Mack dump truck to fix after he changed out a lot air valves the problem started with a bad brake chamber he replaced it with a new one and he told then air started leaking from the back left side relay valve when brakes are released so I took all the valves apart they all ok air is getting to all of them. it is a  MODEL DM685S
Thanks Dan
Vin #1M2B120C1FA055812
Edited by DJG
added content
https://www.bigmacktrucks.com/topic/50380-air-leaking-from-relay-valve/
