I am a new owner of a 1998 RD688S and I just recently encountered some problems and I am seeking help.
1. Just had the #1 plunger replaced because there was no fuel going through that fuel line and once I had that done, I am now seeing white smoke out of my stack, and the turbo is leaking. Can someone offer me some suggestions
2. Also, I just added a gallon of oil and my oil pressure gauge is at 55psi. Do I need to let it warm up to get back to normal?
https://www.bigmacktrucks.com/topic/50485-help/
Item#2-is that at cold startup? normal
get hot and see...around 20 hot idle is ok
hot running at 1600 rpm is about 45 for me-shop says good
https://www.bigmacktrucks.com/topic/50485-help/#findComment-375029
