1 hour ago, terry said:
Like all the 237 mack engines people try to say are 300's.    terry:D
Or 350's that  are actually  300's. That one always  cracks me up. An ad will say "350 Mack,5 spd." Al
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-375610
well, since i have no idea what the difference is between the 160 and 180, i will take you word for it. just figured out i would point out they said it was a 180.
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-375617
how about all those that say they have or have driven a 300+ with a 5 speed.,If I only had a dollar for every argument I've gotten into over that claim.
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-375680
Were the 5sp only available in the 237 and 285? What did the 300 and 350 come with 9sp and higher?
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-375999
there were a lot of real 300's around new England that always seemed to have a 9 speed roadranger in them. dunno if this was just the spec? every 300+ I have seen had a 10 speed roadranger.i don't think that was the only option. most 237's 250's and 275's had 5 speeds, least the ones I have seen
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-376029
Wide ratio transmissions like the 5 speed were (usually) only available with the Maxidyne engines. The Mack Maxidyne 6 came in 237, 285, 250, 275, 300, 335, and 370 HP denominations. IIRC the 335 and 370 were only available from 2001 to 2006. What is advertised as a "350" with a wide ratio 5 or 6 speed is usually a 300 or lesser engine.
https://www.bigmacktrucks.com/topic/50539-b-with-a-cummins/#findComment-376030
