I have a 1996 Mack E7-454 that I would like to upgrade to the air clutch fan. I'm looking for any help with wiring in the factory engine harness, factory install location for the air solenoid switch. I realize I could get a temp switch and high pressure a/c switch and run it that way. Thanks
https://www.bigmacktrucks.com/topic/50584-vmac-ii-air-clutch-fan-wiring/
I'm not working today but I'll try to post a wiring diagram on Monday. On the Vmac II the air fans ran through the ECM. So a trip to the dealer to turn on the parameter will be needed. Or you could run it like the VMAC I or as you said adding sensors. Regardless you will have to add a AC high pressure switch
