My 87 has a tick when its driven and warmed up. Not a constant tick, more of a hit and miss tick. Doesn't do it when it's cold. Thought it was my air conditioner but it's not. that oil is good steped on the clutch still there. Oil pressure is good. Could it be an injector going bad? Thinking if it was a valve, it would be a constant tick. Any ideas? Thanks
https://www.bigmacktrucks.com/topic/50590-350-4v-e6-engine-tick/
I have a 686st .. 1986...E237. It's not the original engine..I bought it as is...I had a ticking noise that would come and go..Thought it was a lifter.
Turned out to be a bad head gasket...the ticking sound was coming from where the head meets the block in one spot. Once I figured it out, you could actually see it leak and tick.
Easy fix..new head gasket..all good for a year now..maybe this will help..
