Daimler issues two separate recalls for Freightliner and Western Start trucks
Land Line (OOIDA)  /  August 2, 2017
Daimler Trucks North America (DTNA) has issued a safety recall for certain Freightliner and Western Star trucks, according to National Highway Traffic Safety Administration documents. Recalls deal with tow hooks and battery cables.
The first recall affects certain 2018 Freightliner and Western Star trucks equipped with tow hooks used for recovery purposes. Tow hooks may fail during use without warning, leading to a sudden release of the vehicle.
Affected trucks include:
  • 2018 Freightliner 114SD
  • 2018 Freightliner 122SD
  • 2018 Freightliner Cascadia
  • 2018 Freightliner M2 Business Class
  • 2018 Western Star 4700
  • 2018 Western Star 5700
Owners will be notified and faulty tow hooks will be replaced for free. The recall is expected to begin on Sept. 14. For more information, call 800-745-8000 with recall number FL-742.
The second recall affects 2014-2017 Freightliner Custom XCR chassis. A battery cable mounting bracket may not have been installed correctly. Consequently, the improperly routed and clipped battery cable can contact the frame rail, possibly causing chafing and short circuiting.
Owners will be notified and dealers will inspect and revise the battery cable mounting bracket and cable routing for free. The recall is expected to begin on Sept. 14. For more information, call 800-745-8000 with recall number FL-741.
Tow hook, fuel pump issues prompt recalls of 2,500-plus Freightliner, Western Star trucks
Matt Cole, Commercial Carrier Journal (CCJ)  /  August 7, 2017
More than 2,500 Freightliner and Western Star trucks, ranging from severe duty to Class 8 long-haul tractors, are included in two separate recalls, according to documents from the National Highway Traffic Safety Administration.
The largest of the two recalls affects approximately 2,483 trucks and was prompted by tow hooks that were not manufactured properly. Recall documents state the tow hooks could fail during a recovery, causing the sudden release of the truck. Trucks affected by this recall are:
NHTSA’s recall number for this recall is 17V-452, and Daimler Trucks North America’s recall number is FL-742. Daimler will notify owners, and dealers will inspect the tow hooks. Depending on the production dates of the tow hooks, dealers may replace them, free of charge.
The other recall affects approximately 74 trucks equipped with Cummins ISX15 engines. In these engines, the fuel pump’s drive gear could slip on its drive shaft, resulting in a loss of function, causing the engine to stall. Paccar issued a similar recall last week that affected more than 1,700 trucks.
Trucks affected by this recall include:
  • 2017-2018 Freightliner 122SD
  • 2017-2018 Western Star 4900
  • 2017-2018 Western Star 5900
The recall also includes 2017-2018 Freightliner Custom Chassis XCM and XCP, which are used for RVs.
Cummins will notify owners of affected trucks, and Cummins dealers will replace the pumps. NHTSA’s recall number is 17V-450, and DTNA’s recall number is FL-744.
