  • 0
95 CH 613 E7 350
Question
I have a 95 Mack with a E7 350 that since I purchased has had to be primed every morning before it'll start. If I turn it off for an hour or two it doesn't give me much trouble. Before recently that was the only problem, it ran like a champ. Now it all of a sudden started surging rpms when i hammer down, empty, on an incline, or when loaded, causing the rpms to ramp, but no extra power. I can't even climb the ramp in the quarry without dropping to 2nd or 3rd gear, when id be able to take it in 5th given I had momentum. It shakes if I shift quickly, I have to ease off and let it "catch up". I'm changing the fuel filters tomorrow, but I was told the likely suspect is fuel injectors? Anyone else have a similar problem?
https://www.bigmacktrucks.com/topic/50735-95-ch-613-e7-350/
4 answers to this question
  • 0
Start by Installing an In-line sight glass and pressure gauge at fuel line coming into pump. I Built a little 12" jumper to link into line. Watch for air bubbles and then monitor fuel pressure during running under load.
The line Gregball is talking about is a troublemaker. It goes to the elbow of the injection pump fuel-out via a little nipple. That motor likely has a restricted orifice to set fuel pressure, no overflow/ball/seat set-up. Any air leaks in a line are a syphon back issue.
The little line should not affect the running though, you may have a couple issues.
https://www.bigmacktrucks.com/topic/50735-95-ch-613-e7-350/#findComment-377443
Answer this question...
