Land Line (OOIDA)  /  August 10, 2017
Paccar is recalling certain Kenworth and Peterbilt trucks after an issue with the electrical system was discovered, according to National Highway Traffic Safety Administration documents. Nearly 6,000 trucks are affected by the recall.
More specifically, certain Kenworth and Peterbilt trucks model 2013-2017 are affected. The vehicles have a spotlight that may short-circuit internally, according to a NHTSA recall acknowledgment. The short circuit may increase the risk of a fire at the cab fuse block.
Among the affected trucks:
2013-2017 Kenworth T680
2013-2017 Kenworth T880
2013-2016 Peterbilt 567
2013-2016 Peterbilt 579
Owners of affected trucks will be notified by Paccar. Dealers will change the polyfuse switch in the spotlight circuit to a standard fuse for free. Recalls will start on Aug. 31.
For more information, call Paccar customer service at 940-591-4220. Paccar’s number for this recall is 17KWC and 717-B.
Faulty spotlight fuse prompts recall of nearly 6,000 Kenworth, Peterbilt trucks
Matt Cole, Commercial Carrier Journal (CCJ)  /  August 15, 2017
Nearly 6,000 Peterbilt and Kenworth trucks equipped with optional spotlights are being recalled due to a potential circuitry problem that could cause a fire, according to National Highway Traffic Safety Administration documents.
Paccar is recalling approximately 5,731 trucks because the optional spotlight circuit on the affected trucks “may not be adequately protected in the event of a short,” increasing the risk of fire at the fuse block.  Affected trucks include:
  • 2013-2017 Kenworth T680 and T880 models manufactured between Jan. 25, 2012, and Nov. 10, 2016
  • 2013-2016 Peterbilt 567 and 79 models manufactured between July 13, 2012, and Dec. 14, 2016
Paccar says the cause of the problem is currently unknown, and multiple fires have occurred that appear to have originated in the spotlight circuit.
NHTSA says Paccar will notify owners beginning Aug. 31, and will change the polyfuse switch in the spotlight circuit to a standard fuse, free of charge, to fix the problem.
Affected truck owners can contact Paccar customer service with Paccar recall numbers 17KWC and 717-B. NHTSA’s recall number is 17V-471.
