Hello everyone, new here and & spent about 45 minutes combing the forums looking for a hint as to where I might locate the voltage regulator on this truck. My dad bought this on a whim, and it has been up to me and a mechanic buddy to fix the overcharging problem we had. We were able to get the old generator out and rebuilt, but we've been unable to locate the voltage regulator to replace it. Any insight as to where it's located would be greatly appreciated. Thanks in advance!
https://www.bigmacktrucks.com/topic/50792-locating-voltage-regulator-1975-cf600/
Behind the Drivers side Jump Seat, If there is a air pack holder you will need to remove it first, if not just lift up the seat back. Most have keyhole slots so they are easy to remove. If you do nor find it on drivers side try passengers side
