LJ is one of my favorites      ive seen photos of LF.......are you saying the differance is LF is usually cummins???? dont quite get it ....i was thinking the extened hood was the differance to allow for a bigger engine:idunno:...bob
https://www.bigmacktrucks.com/topic/50879-sleeper-cab-on-lj-lf/#findComment-378501
The sheet metal is the same between the two models if both are soft nosed.  An LJ hard nose is a little different.
The truck in the picture looks like might be running 24" rubber which makes me lean toward it being an LJT.   I believe there was more chance to find a Cummins under the hood of an LJ than an LF so seeing what looks like a Cummins emblem on the hood side was another clue.
 As always, your mileage may vary...
https://www.bigmacktrucks.com/topic/50879-sleeper-cab-on-lj-lf/#findComment-378510
ok thanks    my uncle had one of them back in the 50s i dont know witch  one he had....have an old snap shot of him washing it.....ill post it here some day when i come across it....cant be too hard to find i came across  it not that long ago...bob
https://www.bigmacktrucks.com/topic/50879-sleeper-cab-on-lj-lf/#findComment-378516
I would lean toward it being an LJ.  Looks to have a Cummins badge on the hood side panel.
Here is the image cleaned up. It is a side ways V and a circle the shadow is paint. I blew it up but the site won't let me post it.  Paul
59a62a6c077e3_59a40f3a5506e_MackDabelcab.jpg.4afefa4d926441e966d50f20b5cfac86(2).thumb.jpg.b621ed680ee74b5dd22f69aeefd094f5.jpg
Edited by 41chevy
https://www.bigmacktrucks.com/topic/50879-sleeper-cab-on-lj-lf/#findComment-378605
Many Thanks, about the i will ask the driver, now he is the CEO of Burstein company at the age of 82. It's the first time i see sleeper cab in Israel for early Mack.
The engine can be Lanova or or Mack 510 or 672..
Guy, Mack END510 and END672 were also Lanova's. They had Lanova pre-chamber design. Just different engines than ED installed in NR models. A kind of next generation.
Cool pics of those L's. Thanks for posting.
https://www.bigmacktrucks.com/topic/50879-sleeper-cab-on-lj-lf/#findComment-378829
  • 3 weeks later...
