I like this way of chassis restoration.
Have you got the crossmembers riveted or bolted up?
It will probably be months before I get to that...I will have the parts sandblasted and paint them. I want to do some work to the engine and other components before I start assembly. I will definitely use bolts...I'm not as meticulous as you!
https://www.bigmacktrucks.com/topic/50913-parts-is-parts/#findComment-378880
I bought Huck Bolts to do my AC frames, same hardware Mack, PAACAR , Navistar and Cat uses on the current chassis' assembly.  Paul
https://www.bigmacktrucks.com/topic/50913-parts-is-parts/#findComment-378881
