I replaced  the fuel pump on my CXU613 MP8. Now it has fuel leakage from the weep hole between fuel pump and power steering pump. I took them back off and separated them again. Then I removed the cover plate from the power steering pump where the fuel pump mounts. I found the shaft that drives both pumps to be grooved in 3 places where the seals and small bearing ride. I had no problems with leakage before. My question is do you think extra pressure from the new fuel pump was enough to cause a leak where none existed before?
https://www.bigmacktrucks.com/topic/50937-fuel-pump-replacement/
Well, I replaced the power steering pump as well and my fuel leak disappeared. but I am still having the same problem. Every now and then it feels like I'm running over a washboard in the road. only lasts for a second or two and when I let off the throttle it quits. The only other time this happened was I almost ran it out of fuel. Found out how inaccurate my fuel gauge was then.  It also seems to have a slight miss and is bogging down when I get to higher rpms. 1600 to 1800. Checked for blockage in fuel tanks but they are clean as a whistle. Not throwing any codes. Seems to be getting worse. I can even feel it when bobtailing. Could the dealer pull codes even though they aren't showing up my dash? It's a 2008 CXU613 with 485HP MP8. Thanks for any thoughts.
You may want to get tour fuel system checked for combustion gases getting into fuel system through tour injector cups. If they have never been done it may need them. A sight glass test in the fuel system will help in the diagnosis.
Thanx for the input. I had them done last fall for the third time. Starts and idles fine. Some times feels like a governor kicking in at about 1600 rpms. The bad thing is it doesn't always do it but getting more frequent. Do you think I got some bad fuel? No water in the separator and the fuel in tanks looks good. Thanx again.
