Your guess is as good as mine FJH.
I use to think Mercedes was spooky. They mount high and stick the filter in a bullet proof canister.
Some of our off-road engines have multiple oil pumps so you can hold the engine nearly vertical (like a dozer climbing a coal pile) and still pick-up oil. Those machines use upside down spin-on (bottom facing upward from top of engine) with check valves in filter to hold oil during engine-off.
Seems like some engineers get a kick out of new ideas, even bad ones. Like plastic surge tanks.
Edited by Mack Technician
https://www.bigmacktrucks.com/topic/50963-filter-section/#findComment-379405
I did the Mercedes school when i was working and we was told that its was cheaper.I think it was around four dollars back in 05.Fuel filter same way and we was told that they were turned upside down so no one could pour dirty fuel in it.They had to be primed to be filled with fuel.
https://www.bigmacktrucks.com/topic/50963-filter-section/#findComment-379441
Kev
sent me these links!
https://www.mann-hummel.com/fileadmin/user_upload/AutomotiveNews/AutomotiveNews_EN/MANN_HUMMEL_Automotive_News_2012-2_en.pdf
http://www.us.mahle.com/mahle_north_america/en/news-and-press/press-releases/modularity-and-functional-integration-in-the-engine-periphery-of-commercial-vehicles-7361
As Glenn mentioned in the log run it comes down to Cheap assness!
(WONDER Why THE big V aint gone Here yet!) ( CHEAP)
And in my mind the  the idea of having to disturb those filter inserts ( CROSS contamination )Far worse than filling a filter with clean fuel or oil!
So one small vote for the volvo method For now! ( Its only a matter of time till Cheap mode kicks in At the Big V !)
Edited by fjh
https://www.bigmacktrucks.com/topic/50963-filter-section/#findComment-379480
