  • 0
2010 Mack CHU613 ATC issue
Question
I have a 2010 CHU613 has code on dash under ABS  Sid  77  FMI 7.  I have changed both front abs sensors and the ATC / AT-3 SOLENOID ASSY.  The modulators seem to be clicking at start up as needed and I have pulled the connections and checked for corrosion.  Where else do I need to look to reset this code?
https://www.bigmacktrucks.com/topic/50982-2010-mack-chu613-atc-issue/
1 answer to this question
  • 0
SID 77 is brake demand sensors. They are located on the foot valve on the fire wall. Go to Bendix.com and go to document library and type in SD-13-4869 and choose troubleshooting and down load it. Bendix and Eaton are great about public access to all their manuals . Also RH Sheppard steering gears too!
Answer this question...
