1 hour ago, russell t said:
Looks great, and it is yours so polish away. Which engine are you using, 377, 401, or 402? If my memory is correct the 377 used an oil cooler and the double fan belts?
It's the 401. It has the dual belts and an  oil cooler in the filter housing. It has a provision for coolant to pass around the housing.
I like to add the details to make it look like I've actually done something. 😁
https://www.bigmacktrucks.com/topic/51100-getting-heavier/#findComment-380525
Wow..........I get SOOOO envious of guys that have trucks restored like this.    Not that I would want to have to take care of it after, but sure do like them all shiny and new.  All of which mine will NEVER be.
https://www.bigmacktrucks.com/topic/51100-getting-heavier/#findComment-380621
The truck is turning out absolutely stunning. Great job.
https://www.bigmacktrucks.com/topic/51100-getting-heavier/#findComment-380622
On 9/25/2017 at 1:38 PM, russell t said:
willy, I am restoring a BM with rubber spring mounting pads similar to the front ones on your truck. I would like to know a source for these mounting pads if you were able to find any new ones.  Thank you in advance
Sure, I'm always looking for parts sources.  Thanks.
https://www.bigmacktrucks.com/topic/51100-getting-heavier/#findComment-380817
